this is incorrect, the spacing between degrees F & C is different. Wiki has the formula. F is 32 is freezing and 212 is boiling, C is 0 is freezing and 100 is boiling
Cx2+30 will get you very close.
the formula is from celcius to farenheits 32+ 9/5 mfrom farenheits is -32 5/9 .
thats why we in america give that up many yrs ago to dumb lol
celcious is easy
0 = freezing
anything below 0 is more freezing. Anything above is not freezing.
Freeze equals when water turns to ice.
Many people try and figure out what is 20 degrees celcicous in feirnhiht..
I am older and when I went to school and many years after we as canadians used standard. An inch was an inch.
No confussion
Then comes metric
Mass confusion in my 12 year old brain.
But
it was easy. Do not try and convert it.
Zero is zero
1 mm x 10 equals 1 cm
1 cm x 10 equals 1 m
1 m x 10 equals 1 thing that is 10 meters long :)
point is , that it is simple based equation. Not like 32 equal zereo. What is that ... :)
Same as the temperature thing. Zereo is zero, or 12 inches in a foot and 3 feet in a yard. A yard is almost same as a meter. Which makes a meter almost the same as 3 feet
And you know what 3 makes... a yard :)
that standard equation is tough to work with
1 meter x 1000 equals 1 km
1 km is about sixth tenths of a mile
example
at 100 km per hour (highway speed of 60 miles per hour)..
You can travel 350 km at that speed of 100 km per hr
how long will that take you É
now try that same calculation in standrad and miles and stuff... you will never come up with answer as fast or easy.
lol,wow now I know why I am having problem with them formulas lol.know metric very well but imperial is another story.
The obvious truth about this outer portal and the weather or time settings is that the people that programmed it lacked the vision that would allow us the proper, user-friendly options for complete setup of all of the given features; or - in other words...the software is incomplete at best! :( Hopefully, it will eventually get better; but, my experience with this iptv so far says, "Don't hold yer breath on that one!"
Couldn't find any way to adjust the time and date. Closest I found was a timeshift option (that there is NO info on whatsoever as to it's proper use/function). For the weather - the smartest/easiest option would have been to simply allow us to enter our zip code - Du-u-uh!
The advertisement for this new iptv stuff TOTALLY overplayed what we are actually getting stuck with here.
My opinion: The people that are supposed to be giving us what we want here are clearly amateurs at best!
All we can do at this point is keep our heads up and hope for the best - as in maybe they'll eventually hire someone that actually knows what he/she is doing with this stuff! :cool:
So forget watching TV then, let's just play with our calculaors instead! :p
