Ok I am a htpc user i have no andriod or emulators i`m using Kodi`s windows versions 17.6 Krypton and 18.3 leia. The aznkodi addon works fine
on both with the 18.3 leia theres bigger icons slowing down Kodi but looks nicer.
The difference between the simple client and the aznaddon or shani`s playlist loader addon is the simple client
wont play Kodi`s plugin addresses these plugin addresses like from the old sportdevil addon are still very useful
in getting iptv from flashsites without their annoying adds there are good sites out there Arconai tv, photocall,123stream,firstone,
ustvgo,PLUTO and streamlive and many sport sites, theres plugin addresses for youtube,filmon,dailymotion,plex and acestreams.
These all update on their own!
Also the the f4m tester addon and its plugin address that will get you free shared m3u`s without cutting out on you better if you find your own
than the ones hundreds are watchin which opens a little secret about how many connections you can have on an iptv service!
here are a couple of examples of some of the Kodi plugin addresses all you do is find a site add the url address of the video to the plugin address
the above are filmons the last one is a youtube playlist it has all the episodes.Code:#EXTINF:-1 test tvg-logo="http://i.imgur.com/pVYoNhX.jpg" ,pugilism-tv
plugin://plugin.video.SportsDevil/?mode=1&item=catcher%3dstreams%26url=http://www.filmon.com/channel/pugilism-tv
#EXTINF:-1 test tvg-logo="http://i.imgur.com/pVYoNhX.jpg" ,fighting-athletes-network
plugin://plugin.video.SportsDevil/?mode=1&item=catcher%3dstreams%26url=http://www.filmon.com/channel/fighting-athletes-network
#EXTINF:-1 test tvg-logo="http://i.imgur.com/pVYoNhX.jpg" ,live-boxing
plugin://plugin.video.SportsDevil/?mode=1&item=catcher%3dstreams%26url=http://www.filmon.com/channel/live-boxing
#EXTINF:-1 test tvg-logo="http://i.imgur.com/pVYoNhX.jpg" ,armed-forces-boxing
plugin://plugin.video.SportsDevil/?mode=1&item=catcher%3dstreams%26url=http://www.filmon.com/channel/armed-forces-boxing
#EXTINF:-1,[COLOR violet]KING OF QUEENS[/COLOR]
plugin://plugin.video.SportsDevil/?mode=1&item=catcher%3dstreams%26url=PL5BmokrJRqVj4Ziaet5xX66oqunyw_MgJ
heres is an non working example of the f4m tester addon
you can do an entire m3u with one click in notepad++ when adding the plugin address.Code:plugin://plugin.video.f4mTester/?streamtype=TSDOWNLOADER&url=http://lunarusa.org:8080/flo/flo2/9172
And yeah pastebins do work on the azn and playlist loader remotely so content can be added anytime
if your a pro user at pastebin you can do a 10mb m3u you can still get a pretty big list as a guest
about 50,000 links.
For the playlist loader to work you must have the sportsdevil addon any version working or not f4m tester youtube and filmon etc loaded on Kodi.
The reason for the playlist is not only what it can do but its a playlist it keeps all your content together use the search feature find you media fast.
The playlist is your own you can share it with friends and family but risky if you release it to the public!!
The big question is will this work on a buzz?!
