Yup!!!
Do you have a MAC# linked to your account?
You cannot connect to get playlist data if you have a MAC#.
You need to set your account to Playlist Access which will remove the MAC#
FYI - You can make a Custom playlist from a template, and access the services while having a MAC#.
You just can't get a full playlist prepared for you by the Server and uploaded for u 2 download.
Shutdown Kodi then Go and do an IPTV Reset.
If it still wont connect, let me know your Portal/ Server.
I tried to download IPTVXtra and got this window saying "the key you provided for file access was invalid"..
Has it been removed?
Edit: NVM got it now. Will give it a whirl and report back. Thanks Ken. You guys do so much for us.
Really appreciate it.
I guess I will have to make a Video!!
Once you click auto-setup of PVR , IPTVXtra loads the playlist file and the guide data into iptv simple client.
Then it enables it. The channels and guide load up, and you get a TV Icon on Home Screen main menu.
click TV and you get a channel list, but the sub menu has the guide selection.(or slide to left of screen and select it from the side menu.
You only use IPTVXtra for accessing VOD. (the iptv menu item is just to load the channel list (no guide data)).
I just started using IPTVExtra (previously using PotatoTV). Im using the HD version of the xml guide and I noticed that no matter what offset I put in the PVR IPTV Simple Client that it doesn't shift any of the times in the guide. I have also made sure that the setting 'apply time shift to all channels' is selected. The time shift worked when I was using PotatoTV with kens guide. Anyone else experiencing this?
Any changes to PVR settings requires clearing of the database.
Disable IPTV Simple client.
Go to system Settings/ PVR&LiveTV/ General tab - clear data and confirm by OK.
Go back to PVR Settings and change the Offset time of the EPG then Save by OK.
Enable the PVR.
That worked, thanks kens
I would just Like to Add a big "THANKS" to kens as it took about 1/2 hour to get this going on Me Friends Kodi MX Box using the PVRSimpleTV player already installed...! She had left a Digit out of the Donation # and when I found it and Put it in the Right Spot, Viola...! Good, NO... Great Stuff, Thanks Kens...!
