Look for my newest post -Fire TV/Fire Stick Channel Surf Fix
I followed the instructions all the way on a fireTV box but i'm getting "Install Codec" with MX Player Pro APK Full Patched v1.7.37.
I tried with MX Player Pro APK with Neon Codec v1.7.37 and I get " Can't play this link" on any channel.Any advise?
you may have been trying a channel that was down. to ensure that you have everything loaded properly go to the videoclub icon and ensure that you can play one of the VODs.
can you guys help me i get this error on aftv stick when i am trying to go to the settings on stb emulator 0.5.25 i got mx sideloaded also. Attachment 429
Don't click/select on the "settings" on the main screen. It doesn't work in the EMU. The real settings are on the top right corner. The first icon will have the portal settings, and the 'three dot menu' which may not be easily seen on the far right controls the operation of the emu.
the problem is that i dont have the Rc icons that appear on the screen. how do i get those to appear. Attachment 431
Hit your return or stop button to get the screen to return. If it doesn't, restart your box and restart the emu to see if you are actually connecting to the server, assuming that you had set that up per instructions. If you see a increasing yellow bar, you are connecting, if not, you need to find a video on how to configure an emu installation.
You have to mouse over the settings on the top right to initially set up the box. The one with the multibar is where you set up the portal to the server settings. The one over to the far right will allow you to select the media player, as well as to exit from the emulator. I don't know if you can mouse with the firetv stick, but that's how you set up the emu.
Please read post #7 on this thread, or look for other stickies on how to set up the emulator.
Here's one for generic pc and android setup:
http://iptvtalk.net/showthread.php?4...V-STB-Emulator
I'm unable to access the setup menu as well. The app is running fine, just can't access the settings menu in the top right when clicking. All the other buttons appear when you click, just not the 4 in the top right-hand corner. I've quit and restarted and reinstalled. Maybe it's a bug in the latest version? I've notified the developer of the issue.
