No service channels will play on Portal 1
Don't see any reports at papiao about this.
Seems channels are okay here.
By service channels, do you mean channels like History Channel and etc ?
No all Papaio channels..tried changing playlists, IPTV reset. will now try Portal change
!!! changing from Portal 1 to Portal 3 SOLVED the problem ! All good now..
you kill your m3u list on your other post
A quick test says it had more than 100 users connected.
http://iptvtalk.net/showthread.php?4...laylist-set-up
When you say you were down it was because you gave your info to everyone
Code:#EXTINF:0,Fight Network
#EXTVLCOPT:network-caching=1000
hxxp://1.iptv11.is:80/*************/*************
ahh so I see. Thnx suport :)
I have deleted the 12 digit code just now from both threads.
You might wanna log in papiao and change that donation number 1sikguy
