Outstanding !! :cool:
I had been racking my brain because I knew there was something else that was simple and could be possible cause.
My brain was starting to hurt :eek:
Just did the update here. I went thru the Update manually option found on the default Home Screen.
It went well.
The first step it shows the percentage indicator loading the file onto the box and then it installs the file in the second step.
No interruptions with ether step were experienced.
I have only one app on this box that I installed besides the default apps that the box comes with.
I have the XRS4500 hard-wired with Ethernet to router.
Them channels that were not working before, are now working, as was confirmed with the beta tests on the XR4000 model.
I have been using the Secondary Player.
MediaPlayer Launcher is no longer crashing.
Crazed you watched a ppv yet just wondering
The hole movie plays now ?
Hearing there ok now
Never tried yet
man you must have chit load apps that take weeks to update then me would take time because of that
When did you guys become free tvers?...lol
me i did it for test how many i could add was chit load i can tell you that and free dont think so for 4k i wish you can do it free but so many hiccups but lower then that a chit load stuff couldn't add it all would take a day for box to update lol never get watch tv i would say all you need is 5 to ten great apps
i said found problem with box nope it was the batteries from the remote lock my box up that was problem so check you batteries now then wow was thinking it was box
I would have thought people would always check the obvious before ranting.....
