https://www.youtube.com/watch?v=qM0yXZk5cHg&t=6s
For Rocket, the Website is http://p1.iptvrocket.tv
For IPTV66, the Website is http://s1.iptv66.tv
The username and password are your rocket or route number. Leave port (80) alone.
The tutorial is using Kodi 17.
Here is a tutorial for Playlist Loader, an alternative to xstream-codes, that can play m3u files or remote links:
It's a little dated, as the latest version of Playlist Loader is 1.1.4+, but the steps to get it are still valid. Instead of xbmc-repos, click on kodi-repos. Use the link you get from your donation/rocket/route checkerCode:https://tutorial-iptv-xbmc.blogspot.com/2015/03/playlist-loader-add-on-for-kodi.html
see this if you don't know how to get your m3u Playlist link:
http://iptvtalk.net/showthread.php?2...065#post181065
- leave your mac on papiao the same (but in reality your mac could be all zeros - thats good to do if you are using another media player such as Perfect Player (besides kodi) since now you dont need to send a mac addy with kodi addon - not a bad idea now to just "IPTV reSet if you are in papiao but not necessary until you first enter the url and see what happens from there...once thats done
so, go back to the addon and in settings, enter your info -
this is the url on the line (website)
http://p1.iptvrocket.tv OR http://s1.iptv66.tv
whichever one you sub
username and password, - leave port at 80,, click ok
exit out and click the addon and click on live tv
pls note; the password you enter is not able to view as you type, so make the entry nice and easy / slow to make sure no mistakes are made..one digit wrong can give you an error
once your extream-code iptv addon is installed go to the settings and replace the path thats there (on the website line) with
http://p1.iptvrocket.tv type it in and then followed by your username and pass
and click OK...should be good to go
manager/add source/
http://srp.nu
then go back to
install from zip/ whatever you named your file (mine is superrepo)/ jarvis/repositories /superepo/(superrepo.kodi.jarvis.repositories-0.7.04.zip)
once installed go to
install from repository/SuperRepo all [jarvis] [v7]./video addons/Xtream-Codes iptv / install
once installed..go to the add on settings/ enter your info . Done!!
entering your info
- website (URL) http:// s1.iptv66.tv OR http://p1.iptvrocket.tv (which ever user subs to)
- username, password
NOTE; password will not show as you type it - very important (to take your time and type in carefully otherwise ONE digit wrong will give an error)
no other entries needed - some users may need to exit kodi and restart kodi - open Xstream codes IPTV and go to My Account (double check info) and/or go directly to Live TV and should be able to connect to server from there on
Edit; Very rare cases - users may need to check their rocket (papiao site) and can input 00.00.00 in their mac replacing their original Mac addy - do IPTV reset may be necessary as last resort to reconnect and rebooting routers
Discussion moved here:
http://iptvtalk.net/showthread.php?2...ate-discussion
