Thank you sir :)
Worked like a charm.
You are Welcome, Now just waiting for DJ to Report Back that he is Good to Go Again again...!!!
Wait no longer, I got it and thanks to all you guys
for your help!!
:cool:...:cool:...:cool: and :cool:...!!!
Sorry I was not around to respond to your confusion, re; no-limits.
As I mentioned, I don't like custom "Builds" of Kodi, but that one has many functioning addon modules.
To get to the point, after you install no-limits, you can browse through all the addons to see which ones are functioning and of use to you.
My recommendation should have mentioned some options like changing back to your Skin you used, disabling all no use addons, etc., or Optionally re-installing Kodi over the No-limits build.
Then go to System settings/ Addons/My Addons/ Video addons - and you should see all addons that came with the custom build, where you could Enable any of interest.
/Shooty
I was working on crazed 8.4 add-ons and I ran into one
problem. The fight club add-on, I get the error message.
Is there another way to get fight club??
Have Heard that Add-on requires a Pin Code which is good for 24 hrs, then need a New One...!!! 4me is certain that if You check some other Add-ons You might bee Surprised to see Other Options for Sports...!! Don't Put All Your Eggs in Just One Basket...! Good Luck...
The BEST Sports ans IPTV addon is the CREW at
Code:https://koditips.com/the-crew-kodi/
