bluestacks gives and error rpc error when i try to install and app.
Bluestacks seems to work best, because it stays on the same tablet aspect, vs. switching to "whatever" like Andy. The STB Emulator will force Andy to go to a "phone" aspect or even upside down, but Andy is more like a real android experience. I'm going to try another emulator called windroy, to see if it works better than bluestacks. I don't like that Bluestacks will force you to install apps that you don't need, but Andy requires that you see ads to use it.
I'm also running the emulator on my "mediabox" android, but it also has some problems with aspect ratios for the application. I can now see why they call the emulator solutions, even on a MAG260, as 'unstable'.
same problems here... im using it on a mag 260, and it is very unstable.. it works, but sometimes the movie doesnt play and you have to exit and force quit the emulator or reset the 260...
dara ..... get mx player apk and let bluestacks install it
This problem exists because you need to adjust the resolution and marry it with your tv resolution so both will become compatible to each other, in the profile option click on resolution and make your adjustment accordingly.
date i got bluestacks i am in the app emulator choices witch one do i download can you give us bit more detail
this for PC wd 7 thanks in advance. You are doing a fantastic job helping members !!!!!
No worry, we learn from each other.
So basically just open the browser inside the bluestacks and type in stb emulator then download it and set it up based on the free trial url by going up right corner and by clicking on fourth option which is on the other side of the rc then just head to the profile option then portal setting apply the url then go to the mac address and change the last three set of your numbers, then adjust your resolution.
really ez they said it would work just not good
acutally, i read post elsewhere to download mxplayer.apk which i did for the 260, and the problem is gone!!!! i can now switch between movies, stop a movie and start another without restarting the device.... Runs very stable at this minute!!!
believe it was Scully came up with that...nice catch, Scully..
